Is it possible to insert a hyperlink in a Pro attribute table? If so, would I create a "text" field. Also, some hyperlinks are very long and I'm concerned about field length. The client would like to have the link in the popup. Thanks.
I tried adding a link to an external document
Yes, the article is specific to adding a link to an attribute table, as you asked. I'm not sure what you mean by an 'external' document. You can also add links to pop ups.
See: https://support.esri.com/en/technical-article/000018754
Thanks, Joe. The article indicates adding a hyperlink in the attribute table can be inserted to point to an individual feature in a feature layer. I tried adding a link to an external document (zoning map for a particular town in NJ) but it doesn't seem to work. I'll keep trying. Thanks for your help.
Jim
For example, can I add the following hyperlink in the Hyperlink field cell for West Cape May Borough:
West Cape May Borough Zoning Map
