It is ridiculous that vector data uploaded to AGOL, but intended for use in ArcGIS Pro cannot support complex symbology. From what I've read the intention of the downgrade is to make data intended for webmaps compatible with browsers, but there should be an opt-out for data that is solely intended for use with ArcGIS Pro.
Vector tile services do not provide the attribute based functionality our clients demand, the workaround draping tiles over invisible vectors is clunky (to say the least) and the use of layer files in AGOL pointed at feature layers is causing us authentication issues in collaborations.
All of this could easily be solved by supporting complex symbology in vector feature layers!
