I wanted to post this a question that I am working on to learn about Creating your first dashboard using ArcGIS dashboards here : https://www.esri.com/arcgis-blog/products/ops-dashboard/mapping/create-first-arcgis-dashboards/
It seems like on Step 6 it talks about trigger on the Map Actions tab.
Well it seem like this page has not update to reflect the latest update. Mine had said Actions tab and then it says When Selections changes and then when I click on the Add Target. and was able to add list..
BUT if you go to the same thing for Trigger for the flash on step 7 and I was able to add this flash from the Add Target.
All good but it did not mention to save it before you go back to Configure . How is that possible ?
Because in order for you to go back to Configure , you need to save it. When I did that and went back to Configure again and I don't see any trigger at all.
