Hi folks
Any help would be appreciated here. I've used survey 123 for a couple of years but only really used the templates and tweaked them a little for my own purposes. After setting these up a few years back I'd like to refine them now that survey 123 has advanced and the surveys have too.
One survey I would like to develop is a field survey for plants across several catchments. I'd like to eliminate any errors by having selections provide the correct fields on offer during the site selection process.
I started to use a template to create a cascading select to pre-select a survey site list based on catchment and partner lists. However I cannot seem to get it to work. I've tried to use the cascading selects example using a Regex style but with no luck. See link and attached attempt
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformcascadingselects.htm
I've not used survey 123 all that recently and am a bit rusty, any pointers would be greatly appreciated.
Best regards Jamie
