I have a survey123 form that is linked to Collector. People can go to the area and access the form from collector and it will pre-populate. I currently have the setting "Require Update to the Latest Version of the Survey" turned on. However, if you access my survey from collector you can collect without having to update the survey. Only if you click the survey inside survey123. Is there a way to make it so that when i update the survey it makes it so they have to update it as well when using the pop-up in Collector?
