It would be useful to be able to create a point based on a measured line, similar to using Create Features in ArcMap, where there is an option for "Point at end of line" under Construction Tools.
For example, if you are inside a building or under heavy tree cover, you may have no or limited GPS. Currently, the only option is to drop and pin and choose Collect Here, or to click the plus and then collect the point based on the Target. You should have the option to measure a distance on screen and place a point at the end of the measurement. This allows you to physically measure from a landmark (e.g. from a building corner using a tape measure) and place the point in Field Maps by measuring the distance from that landmark. That way you could collect point locations with some level of accuracy even when no GPS is available.
The current measure tool is of limited use because the measurement disappears once you click Done.
