Hello, I need to draw route between two points. I have tested San Diego example that document showed. Now I need to use in my area Sri Lanka. When I used I got check getCause(). How do I use routing feature in my area Sri Lanka. I saw some configuration in example like:
<string name="navigation_vector">https://www.arcgis.com/sharing/rest/content/items/dcbbba0edf094eaa81af19298b9c6247/resources/styles/root.json</string><string name="routing_service">https://sampleserver6.arcgisonline.com/arcgis/rest/services/NetworkAnalysis/SanDiego/NAServer/Route</string>
The sample code uses a dataset which I believe only covers the San Diego area. It's a demo service and not designed for production use. If you want to perform routing operations in other areas you will need to use a different service.
You have a couple of options here, you can either make your own data, or you can use one of the services we host. There is lots of information about it here:
https://developers.arcgis.com/android/route-and-directions/
Does this help?
