I am in a process of building a UN model for Water Distribution. It is set-up correctly mostly similar to Naperville model and can see subnetworks and run traces etc.
Now I need to add an additional code to VALVE_STATUS domain called "Partial" to represent that a valve is partially open. I stopped UN services and disabled UN topology. I then added a code 4 with description of "Partial" to appropriate domains i.e. Valve_Status and Device_Status_Combined.
I then reenabled the topology. When I change one of the valves from "Open"
to "Partial", it becomes a barrier and the network downstream is left out of the subnetwork after Validate and Update subnetwork. The tier is defined only with Present_Status=0 (closed) as a barrier. So Present_Status of 4 (Partial) should not become a barrier.
Am I missing something?
Cheers,
Vish
