Hi every one
I want to remove attachment from popup result
Thank you very much ... I do what you are talking about .. the attachments doesn't appear in any pop-up .
It appear in Result pop-up only why!!!
Pleas see attached pic
Thanks ...
Just go into your web map and configure the pop-up. Below the list of field there will be an option which allows you to switch the hyperlink to the attachment off (see below, sorry for the Spanish interface):
First of all thank you very much
But i did not wont to delete the attachment , i want to hide it ( attachment ) the link from the PopUp menu in result query
thanks
To remove an attachment you should edit the layer. If you are the designer of the WAB application you should add the hosted feature layer with edit capabilities and use the Edit widget—Web AppBuilder for ArcGIS | ArcGIS to delete the related record.
