<?xml version="1.0" encoding="utf-8"?> <!-- Copyright (c) 2012 ESRI All rights reserved under the copyright laws of the United States and applicable international laws, treaties, and conventions. You may freely redistribute and use this sample code, with or without modification, provided you include the original copyright notice and use restrictions. See use restrictions in use_restrictions.txt. --> <!--- The custom skin class for the AttributeInspector component used in the RelationshipInspector. <p><b>Since:</b> ArcGIS API 3.1 for Flex</p> --> <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:fieldClasses="com.esri.ags.samples.skins.fieldClasses.*"> <!-- host component --> <fx:Metadata> /** * A strongly typed property that references the component to which this skin is applied. */ [HostComponent("com.esri.ags.components.AttributeInspector")] </fx:Metadata> <fx:Declarations> <fx:Component id="codedValueDomainField"> <fieldClasses:CodedValueDomainField/> </fx:Component> <fx:Component id="dateField"> <fieldClasses:CalendarField/> </fx:Component> <fx:Component id="doubleField"> <fieldClasses:DoubleField/> </fx:Component> <fx:Component id="integerField"> <fieldClasses:IntegerField/> </fx:Component> <fx:Component id="labelField"> <fieldClasses:LabelField/> </fx:Component> <fx:Component id="memoField"> <fieldClasses:MemoField/> </fx:Component> <fx:Component id="rangeDomainField"> <fieldClasses:RangeDomainField/> </fx:Component> <fx:Component id="singleField"> <fieldClasses:DoubleField/> </fx:Component> <fx:Component id="smallIntegerField"> <fieldClasses:IntegerField/> </fx:Component> <fx:Component id="stringField"> <fieldClasses:StringField/> </fx:Component> <fx:Component id="textField"> <fieldClasses:TextField/> </fx:Component> <fx:Component id="typeField"> <fieldClasses:TypeField/> </fx:Component> </fx:Declarations> <!-- states --> <s:states> <s:State name="normal"/> <s:State name="disabled"/> <s:State name="invalid"/> </s:states> <s:layout> <s:VerticalLayout horizontalAlign="center"/> </s:layout> <s:HGroup gap="8" includeInLayout="{hostComponent.numFeatures > 1}" verticalAlign="middle" visible="{hostComponent.numFeatures > 1}"> <!--- Button to go to the previous feature in the selection set. --> <s:Button id="previousButton" enabled.disabled="false" skinClass="com.esri.ags.samples.skins.ContentNavigatorPreviousButtonSkin"/> <!--- Form to display the attributes of the active feature. --> <s:Label width="100%" fontWeight="bold" text="{hostComponent.activeFeatureIndex+1} {resourceManager.getString('ESRIMessages','attributeInspectorOf')} {hostComponent.numFeatures}" textAlign="center"/> <!--- Button to go to the next feature in the selection set. --> <s:Button id="nextButton" enabled.disabled="false" skinClass="com.esri.ags.samples.skins.ContentNavigatorNextButtonSkin"/> </s:HGroup> <!--- @private --> <s:List id="list" width="100%" height="100%" borderVisible="false" enabled.disabled="false" hasFocusableChildren="true" horizontalScrollPolicy="auto" itemRenderer="com.esri.ags.samples.skins.supportClasses.AttributeInspectorRenderer" maxHeight="{hostComponent.getStyle('formMaxHeight')}" useVirtualLayout="false" verticalScrollPolicy="auto"> <s:layout> <s:FormLayout gap="0" paddingBottom="5" paddingLeft="5" paddingRight="5" paddingTop="5"/> </s:layout> </s:List> <s:HGroup width="100%" horizontalAlign="center" verticalAlign="middle"> <!--- Button to delete the active feature. --> <s:Button id="deleteButton" buttonMode="true" enabled.disabled="false" label="{hostComponent.deleteButtonLabel}" skinClass="com.esri.ags.samples.skins.AttributeInspectorDeleteButtonSkin"/> <!--- Button to indicate completion of editing/viewing attributes --> <s:Button id="okButton" enabled.disabled="false" label="{hostComponent.okButtonLabel}"/> </s:HGroup> </s:Skin>
