Hello:
Many thanks
Jorge L. Navarro
The Weather Partner
Hi Jorge,
I had the same problem until I found Ops Dashboard URL parameters. You can set a Parameter for dates and date ranges. One of our developers looked at the ArcGIS JavaScript API Timeslider widget and created a very simple app that sends the dates via URL parameters to the Ops Dashboards - you can link all widgets to update via the URLs. The TimeSlider widget has various modes for Single date, Date Range/Window and Cumulative. Also auto play and Speed mode. This is a great interim solution. If you use AGOL, you need to host the script, but it can reference the online Dashboard - All security is through AGOL.
Hope this helps.
Rudolf
Rudolf:
Many thanks for your response. If my understanding is correct, *to retrieve
and show a specific snapshot* I have to send to the dashboard, via its
calling url, a parameter with the snapshot, that is, something like
"?ts=202000603". And then I have to somehow, in the Dashboard edit
internals, link this value with the corresponding table field.
Is this right?
