I would kindly like to ask questions about some operations of Insights for ArcGis 3.3.1.2106 (used by Arcgis Enterprise 10.7.1):
Adding a map and dashboards in which I have enabled cross filters, is it possible filtering data directly from Dashboards using cascade filters?
Is there the possibility to add quantity filters? (e.g. can i allow to my users to filter the municipalities in a map based on the number of inhabitants?)
After adding a table is it possible export it? in what format?
Giada
Hi @GeoIntelligenceUS , I will paste your questions below, and put comments under each. Just a note in general, if you could upgrade from 3.3, that would be highly suggested. Version 3.3 is actually retired. The latest version of Insights to run off of Enterprise 10.7.1 is Insights 2020.3, and it will give you lots of improvements.
