Hi all,
I'm a relative beginner on Story Maps working in an educational setting. I've built some maps on ArcGIS Online using CSV layers from the web -- Google Sheets specifically. On the ArcGIS Online side, the layer appears fine. But when I try to bring that map into Story Maps, the layer disappears. Interestingly, I was able to add maps with hosted CSV file layers on two other pages in the same Story Map. In fact, to test things out, I built a map using a web CSV file that I had already used in another map which worked in Story Maps. So the problem is not in the CSV file, I don't think. Is there a limit on the number of web hosted maps allowed on Story Maps?
Here's the story.... if it helps. https://arcg.is/1KHqCP
By the way, I have published to "everyone" in ArcGIS Online and in Story Maps. So I don't think this is an issue.
Any assistance you could provide would be brilliant!
Thank you,
Chris
