Note that if you're adding your data directly to a webmap, in the form of a csv or shapefile, you won't be able to download that shapefile. Those edits will only exist in that webmap. Use hosted feature services if you'd like to synchronize updates back with local databases.
Could you please clarity the best way to pull my data back down from the ArcGIS Online cloud? From what i can figure out the best way to make this round trip is to;1. publish a hosted service2. make edits to that service in the field3. pull that service into ArcMap 10.14. zoom to full extent so all my data is visible5. Use the "Create Local Copy for Editing" menu item6. look at the source info after local copy is created to find the temporary geodatabase created. For example C:\Users\bobsmith\Documents\ArcGIS\FeatureServiceLocalEdits\Test2_Photos\fs44EC24DEB05E4A25919747AC3CB9C379.gdbThis seems to be the only way I can get all my data back including the attachments (photos) created in the field. It would seem there should be a better way. It is my data and I need it back to load into our enterprise SDE database when done with field collection.
Has there been any progress about this issue?
From the item page of the feature layer, you can click on a layer (small arrow next to layer name) and export it to a file geodatabase that will contain all attachments.
Mike
Mike,
I've tried this several times on multiple feature services and get an error each time. Each service has 7,000+ points with attachments. Is there a size limit for creating a file geodatabase this way?
Hi Michael,
There shouldn't be a limit. Can you share your feature service with us so we can check it out?
Was this problem ever resolved? I want to download photos collected with Collector on a service hosted on AGOL (not server). I tried all methods mentioned above with no success. How can I download the data with attachments (maybe as relative paths to another db?)
Melanie Rosenberg
You should be able to go to the item page, find the layer in question that contains the attachments, then click the small arrow next to the layer name to export to a file geodatabase. The file geodatabase should get created as a file item in My Content, which you can then download.
If you are having problems exporting, there may be a problem that is specific to your hosted layer. In this case, I recommend calling Esri Support so they can troubleshoot the problem.
hello all,
is there a way to load features to existing backup geodatabase along with the attachments captured using collector for AcrGIS?
