According to this guide, Ctrl-Alt-C is supposed to activate the Explore tool when looking at map in Pro. Similarly, Ctrl-Alt-S is supposed to open select. Neither of those does anything for me. Is it possible Windows or something else is overriding those? Any idea where to check?
Using the ribbon keyboard shortcuts, I can get to the Map ribbon (Alt-M) and the Explore tool (E), but my only options are to switch the Explore mode (Topmost Layer, Visible Layers, etc.), but if there's a way activate it, I haven't found it.
If I do the same with Select (Alt-M >> SE), I can switch between the various select options. I cannot figure out how to close the controls, but if I click anywhere, it gets out of that mode and the Select tool is activated, so this is a partial win.
