Anybody who can direct me to the ArcGIS Pro Python reference for Pro 3.3.3?
Trying to access layer properties (description/tags/ect) in arcpy...
There is no arcpy 3.3.3. You will have to use the help topics for what is currently available which is arcpy for arcgis pro 2.6 or 2.7. Select the version on this page for example.
Alphabetical list of ArcPy functions—ArcGIS Pro | Documentation
You organization may have older versions available through your My Esri login, under your organization then downloads. If you need old versions going forward, then you should download the help topic for your version and use it rather than the online help
Hi Dan, Thanks for your response. Yes we are on AG-Pro 2.3. The available online source does not go further back then 2.6..I can not find a resource for the older 2.3 class reference..
As Dan points out, the only viable path forward is to download the Pro 2.3 Offline Help through My Esri. If you don't have access to My Esri to download it, you will need to contact someone in your organization that does and have the download it for you.
