Is it possible to connect somehow query results and attribute table? I need to have an option to print query results or export them to CSV? I know it is possible to do it through attribute table. But query results are not selected in the attribute table
Hi Liana,
If you are using the Query widget in WAB, then you can make the query happen as an operational layer. From there, you should be able to open the attribute table of this operational layer (which would be your queried information) and print.
Hi Adrian Welsh, I tried the same steps but the ' Open Attribute Table' button doesn't show up in the operational layer pull down menu.
For that matter, the 'Open Attribute Table' does not appear in any of my attribute table. I have enabled 'query' capability for all my services.
Got it! I was manually opening the attribute table.. THANK YOU SO MUCH!
Liana,
When I perform a query and add the result as an operational layer, I have to look at that operational layer in my Layer List. That is where I would pull down the table for it.
I hope this helps.
Hi Adrian,
That is what I am looking for, but for some reason I don't see queried results in the attribute table. Refresh button does not help.. I checked that i am clicking "Add result as operational layer" before querying...
