I recently updated to ArcGIS Pro 2.7. I also updated the oriented imagery plug in 2.5 and the updated oriented imagery geoprocessing toolbox. I create a local project with a map (2D), I add the oriented imagery toolbox to my project, I then use the toolbox Create Oriented Imagery Catalog, that works fine the two feature classes are created for Exposure Points and Coverage Map. Then I use the oriented imagery geoprocessing tool box to try and add images to oriented imagery catalog. I choose the OIC from the drop down list, input type is folder, I point to a network share folder (same one that I have been uses in ArcGIS Pro 2.5 just fine), file filter is .jpg, I'm leaving DEM blank, i'm setting the imagery type to: Drone Oblique Camera. Then I click Run. The process runs with no error shows but never progresses and doesn't stop. If I try to stop the process it won't stop and I have to force close ArcGIS Pro with Windows Task Manager. Any ideas?
Matt Shellenberger
