Hello, I want to create a geoform but I cannot create a subtype field. the first column should have options, but it doesn't look like that. it looks like a normal text forehead. how can i fix this?https://6grup.maps.arcgis.com/apps/GeoForm/index.html?appid=bf64b1a9301445ba825b590de6b9df87
Merhaba, bir jeoform oluşturmak istiyorum ancak bir alt uç alanı oluşturamıyorum. ilk sütunun boyutları, ancak öyle görünmüyor. normal bir metin alnına benziyor. bunu nasıl düzeltebilirim? https://yadi.sk/i/Y1AQqAH4H-5gYw https://6grup.maps.arcgis.com/apps/GeoForm/index.html?appid=bf64b1a9301445ba825b590de6b9df87
Hi, I'd never heard of Geoform before, it looks like it could be quite useful, thanks.
Does you feature have subtypes/domains initially? If so, do they work in the normal editing widget?
i created a .csv file and imported it into arcgis online
https://arcg.is/0XTCTb1
I'm not sure you can create the subtypes from within Geoform, but only having heard of it today makes my opinion on this almost worthless. I also don't think you can create the subtypes in AGOL (though again I don't use it).
Perhaps this may be of use to you - Define attribute lists and ranges—ArcGIS Online Help | Documentation
