This post relates to two aspects of the Manage template pane.
1. Manage (feature) template pane layout & functioning
2. Performance when managing templates
I often experience mayor performance issues in ArcGIS pro and have recently changed to a more powerful PC and that generally helps but the software often bogs up and underperformces. This is one current example plus one general idea of the layout and functioning of managing templates.
1.
When I press 'manage templates' what I want to do is get a good overview and be able to edit all avaible templates as well as layers without templates. The current design does not give me this option. All I get is a general list of all layers without information on whether the layer contains a template or not (in the list). From there I can enter each induvidual layer and do adjustments. For me this wouldn't be a 'manage' function but just 'change'. In the current map I have added lyr files created in ArcMap which have created a whole lot of templates from the lyr.
2.
The second part of the problem is that every click in the Template manager results in a brain freeze and hogs up ArcGIS totally for 15+ seconds (often significantly more). A simple click on a layer in the template manager resulted in 41 % usage of CPU power (according to taskmanager). I do believe the amount of layers (which is the reasons I want to manage them) is part of the performance problem but even so its clearly built in a ineffective way.
Specifications:
ArcGIS Pro 2.6.0
Windows 10, 64-bit
CPU Intel Core i7-10750H, 2,6 GHz, 6 cores 12 threads.
16 GB ram
GPU Nvidia Quadro P620
