Currently a map can only be used online or offline. While the option to download either one or several offline areas should be maintained, an additional online map should be made available. Thus, you would not need to delete the offline areas when you want to go online which is not user-friendly (the synchronization takes a long time in each case and the storage space on the devices is limiting). The simultaneous use of offline areas and an online map is needed by field staff for overview and work coordination. Please provide for the same map following options (see attached picture):
- Online map which can be viewed/edited, e.g. online see below
- Download user defined areas which can be viewed/edited, e.g. Bereich 1 see below.
- Download predefined offline areas which can be viewed/edited, e.g., Nord and Süd see below.
