When entering a traverse you can do most things without entering an exception code, see my other idea for curve entry parameters, which means that when entering a traverse you can do the entire data entry with only the number pad (ten key pad). Could you please add a way to reverse a bearing without having to do it as a mouse click like what was in ArcGIS Desktop? Since this feature seems to be completely gone now at a minimum at least add back in the Reverse Bearing option as a mouse click.
