Hi, I am trying to create map series of every house plot contained in my study with all the attributes contained in it (ex well, septic tank, etc). The problem is that the plots varie a lot in size. I am now using the "Best fix extent" with a margin size of 0% and it works fine with squared plots, but it does not seem ok with long rectangles because the attributes are too small (see the two examples).
1) Is there a way to zoom to the attributes when the plot is too big.
2) Is there a way to rotate every map from the serie to see the attributes as much as possible?
I don't know if my question is clear, but thank you in advance!
