For a few weeks, I have been receiving this error when I open my survey in webform?
Has anyone ever had this error?
I'm using the latest version (3.11) with this configuration: https: //survey123.arcgis.com/?portalurl=...
Thank you
I'm also getting this same error message when trying to edit a survey on the web form. Has anyone figured out the cause of this?
Michael
Hi @JenniferMcKee__GISP,
Thanks for the additional information, I will pass this issue onto our web team, and they will take a look and get back to you.
Regards,
Phil.
@Anonymous User Attached is the xls form, no media files are being used. Thank you very much.
No, it appears we did not make any progress with the exact issue the user above was having.
Can you please share your xlsx file and any files from the media folder or scripts folder, so we can take a closer look as to why it will not open in the web app.
@Anonymous User what was the resolution to this issue? I am currently experiencing the same issue with a web form of my survey developed in Survey123 Connect ver 3.11
Here is the xlsx and js files.
Hi @geomatique_devvs,
How did you create the survey, in web designer or Connect?
If in Connect, can you send please share the xlsx file from the survey folder, so we can take a closer look. Plus also any files in the media folder the survey is using.
