Hi everyone,
This is my first ever post. I am having trouble mapping latitude and longitude coordinates in ArcMap. I am having trouble plotting XY coordinates in ArcMap 10.7. I imported points from a device called PocketLab. These are normal XY coordinates, but when I turned them into a feature class and tried to overlay them on the Oregon counties, they don't show up. I can confirm that the coordinate system and dataframe match for all my items.
Things should work fine from Excel. Just follow the step by step in the KB article and you should be fine.
You do not need a shapefile to plot points, they are "events" dynamically drawn from the table. You can then right click the event layer, save as shapefile or feature class once you have the points plotting on the map.
This is all detailed in the KB article.
Steps are:
0. Open ArcMap, do not load an existing MXD.
1. add a table to ArcMap, this can be an Excel worksheet or .csv file. If using .csv ensure you have a header row.
2. look at your table in ArcMap, what are the x and y fields called? Look at the coordinates, are they longitude and latitude decimal degrees or something else like UTM?
3. Use Map an XY option on the table, use the field names identified in step 2 as input.
4. You will see your points on the map and a New Layer will be added to the map
you now have two options, define the projection for the Layer and Save to a .lyr file
OR
5. right click on the layer and Export Data to Shapefile.
6. Use the Define Projection in ArcToolbox to set the projection.
Now when you load the shapefile or layer file into your 'other map' it will be reprojected on the fly to match your Map document.
I should have added, when you calculate the coordinate system, don't specify an output coordinate system. You want them to be in the shape's coordinate geometry as noted in the link
The output POINT_X and POINT_Y field values are based on the coordinate system of the dataset, not the coordinate system of the map display.
You don't want to do this part
To force the POINT_X and POINT_Y values to be in a coordinate system different than the input dataset, set the Output Coordinate System environment.
Nicholas,
Project will not solve your problem because the coordinate system was set wrong when you read in the points. You need to delete your points and start again. If you set the coordinate system in the Add XY dialog to match your XY coords in the table on the initial add xy to map , the points will plot on your map in the right place no matter what the data frame coordinate system is set to.
Please read the KB article I linked, it walks you through the process, step by step.
Have you tried to add the coordinates to the table to confirm them.
Add XY Coordinates (Data Management)—ArcMap | Documentation (arcgis.com)
Thanks for the quick reply. I tried using the Project (data management) tool to reproject all of my items to WGS 1984 Geographic Coordinate System. This didn't end up changing anything. I also tried setting my data frame to the same coordinate system as my items.
Since I can only seem to change the coordinate system of the data frame itself through the properties menu, I ended up using ArcToolbox to fix the problem. Points are still not showing up over the oregon shapefile even though I can confirm they are all in the same coordinate system.
This is a shortcoming in the ArcMap interface they fixed in Pro. Unfortunately when you try to add XY the interface by default assumes the coordinate system of your points is the same as the data frame (map). The fix (Step 8 in the KB article) is to change the coordinate system (in the dialog, not the data frame's [map's] coordinate system) to one that matches the XYs in the Table fields. Probably something like GCS WGS84 (a common default for GPS data).
Here is an Esri KB article that walks you through the process with lots of detail:
https://support.esri.com/en/technical-article/000018076
I also like to plug a friend of mine's book: Lining Up Data in ArcGIS. It's awesome.
guess you missed that in my post
I suspect that your long-lat points don't have a defined Geographic Coordinate System (perhaps GCS WGS84)
Hey NicholasSievers,
You need to change the coordinate system to a geographic coordinate system to present the Lat and Long.
and your map of Oregon seems to be in a web mercator projected coordinate system. If your points don't have a defined coordinate system then they won't project-on-the-fly to that of the map.
data-management/define-projection
I can't view the photos for some reason, so here they are again.
