I've just started using Experience Builder and have just created my first dashboard. I noticed several bugs here and there.
1) FIlter tools on the map don't work appropriately on large datasets, if the selected area is large enough, it will only randomly select some features, but not all features within the selection area.
2) Filter widget ( not within the map) is also not working great. I have two separate filter widgets referencing the same feature layer. Each filter widget has its own several filters with OR statements.
If you toggle 1 filter within 1st widget, and 1 filter within 2nd widget, it will work fine, and the data will be filtered by both parameters. If you attempt to toggle 1 filter within 1st widget and toggle 2 filter options within the second widget, then first filter widget will break, and the features will be only filtered by 2 options on the second filter widget.
3) If you click on full screen button on the map, all the data will be unfiltered.
4) No way to change columns layout in attribute table.
5) No way to filter attribute table by field.
6) No way to export attribute table data with selections.
I really liked how you can use scalebar with list and features info widgets.
Thank you,
Yulia
