Field name gets truncated for shape file
4753
08-28-2013 08:33 PM
GraceGrace
When I export my data into shape file, I noticed that most of my fields are truncated to just length 10.
I tried to create a new alias, but it doesn't seem to save the changes.
Is there a way for my field names to retain while exporting the data into shape files?
Grace
TimWitt
Yes 10 characters are the most you can have in a shapefile. Your only option is to export it into a geodatabase, is that an option for you? It also depends on what you want to use this data for, this might help find alternatives.
AdamGuo
Add the shapefile in ArcMap, create your field alias names and then save the layer file. The layer file will retain the alias names when you add it back to AGX.
ANANDC
