I have a set of Attribute Rules but in some cases I may prefer to disable/re-enable a subset of the rules in my list. In the current ArcPro 3.2.1 interface I have to individually select then disable or enable each rule one a time. And after I have done so, I can not graphically see which rules in my list are currently enabled or disabled. If there was an enable/disable checkbox column to the left of the 'Rule Name' column. I could quickly enable or disable multiple rules AND very importantly be able to see at a glance which rules in the list are enabled..
See screenshot below of current UI
