I have a series of JPG images with corresponding pixel coordinates on the image which will be used as the source control points for georeferencing. I know where the target points are in the coordinate plane so I would like to match the source point (in pixels) to the target point (in meters) using arcpy functionality. I've tried using the Warp tool which I understand expects the source points to also be in the units of the coordinate plane and since I only know the pixel position this doesn't work.
Is there a way I can achieve this?
