I have a bunch of vector layers, most small, but one is the territorial water of a country, so that layer is quite large. I'm using Feature to Raster and Output cell size of 0.05. I am trying to find the analyze how the smaller layers overlap with the territorial water. The problem is that the territorial water layer takes forever (to the point where I force shutdown ArcGIS Pro) because it sits at 0% processed for over an hour and does not go farther than that. The output cell size for the water layer is 1000. I tried to resample the layer to use 0.05 but I am having the same problem. I am pretty sure the output cell size must be the same between all layers in order to properly run stats on it. Any advice or new ideas ?
