For example, it is possible to create an Indicator showing alert duration but it can currently only be displayed in minutes. We're trying to report on average alert duration so given that some alerts are open for minutes whereas some are open for several hours, hours would be a more meaningful unit to show. It would be good if it were possible to manually convert (for example using an expression when creating an indicator or other element) or have pre-set conversions to get metrics in different units.
Ultimately this is about having greater control over the metrics reported on in analysis.
