ArcGIS Monitor 2023.3.1 Enhancements
318
a month ago
AYUSHYADAV
New Contributor III
I have installed and configured the ArcGIS monitor 2023.3.1. After that, create a dashboard by following this - https://www.esri.com/arcgis-blog/products/monitor/administration/arcgis-monitor-analysis-elements-fo...
We have identified two bugs which are listed below:-
1. We have more than 10000 layers on the portal, and on the dashboard, the value is capping at 10000 only.      Below is the screenshot for the same:-
2. We have identified that sometimes the value of Active users and Total users is shown in decimals. I am attaching the screenshot of the data expression we have used.
I just wanted to know if I am missing anything or if this is the limitation on the ArcGIS monitor. If it is a limitation, then can we log an enhancement for the same or not?
Thanks
Ayush
3 Comments
GeoJen
by Esri Contributor
Hi @AYUSHYADAV
Thanks for submitting an idea!
1. Our team has opened an enhancement in our development backlog to address returning all of the layers in portal
2. The value of Active users and Total users is shown as a decimal because the statistic type is set to average for the indicator in your last screen shot. A better statistic type for the indicator would be max.
DerekLaw
Hi @AYUSHYADAV,
On item 2, we will update the blog post you referenced to reflect the change that @GeoJen mentioned.
Best
AYUSHYADAV
Thanks, @GeoJen & @DerekLaw for your reply.
