ArcGIS Experience Builder format legend
295
02-21-2024 06:25 AM
JonathanHall3
Hi, I'm having difficulty formatting a map legend in ArcGIS ExperienceBuilder.  I've put the legend in card layout with the items and symbols laid out horizontally.  However, I cannot seem to delete the title of the whole legend, and from the title bar to the content of the legend there is a large black margin/padding.  How can I remove this?
JwHayes
@JonathanHall3  I've always removed the title from the legend in the parent map.
JonathanHall3
Hi, thanks for this, is it possible to exclude certain fields in the legend in the parent map?
Shen_Zhang
Hi @JonathanHall3
The title background color cannot be changed for now - it honors the theme color settings. You can see the title background color changes as you change between different themes. This is designed to ensure your app visual accessibility.
However, I think this is a good point to enhance. Please feel free to reach Esri support if you need this function to be registered as an enhancement. We will evaluate the priority of this issue along the way. Thanks!
Shen Zhang
