2.2M
76
Open | There are times when I post a question to a given community but then later realize it would be better suited to a dif... by Bud Notable Contributor 0 1 | 0 | 1 | |
Open | Community questions allow nested replies (replies to existing replies). But ideas only allow single-level comments. I... by Bud Notable Contributor 0 0 | 0 | 0 | |
Open | I would like to have the possibility of fixing layers in the "Contents" window. Sometimes when I add several layers t... by Zameskalo New Contributor II 0 0 | 0 | 0 | |
Open | In the ArcGIS Pro Questions community, I wonder if it would help to force users to tell us the following in mandatory... by Bud Notable Contributor 2 0 | 2 | 0 | |
Open | I noticed that some ideas have a status of Under Review.Here are a few of my posts that are examples.IdeaCommunitySta... by Bud Notable Contributor 2 1 | 2 | 1 | |
Implemented | I often need to attach mobile geodatabase data to ideas, questions, or private messages to Esri staff (such as @SSWoo... by Bud Notable Contributor 0 14 | 0 | 14 | |
Closed | The current community answers to questions suffers severely from bloat. It is not easy to separate comments from solu... by Wunderkind New Contributor II 1 2 | 1 | 2 | |
Closed | It would be nice if there was a dark mode theme for ESRI Community. Almost all my work in other apps, including Pro, ... by GregKeith Occasional Contributor III 0 5 | 0 | 5 | |
Closed | I noticed this Videos post has a mute button: Field Map Parameters Part 1 - ArcGIS Pro 3.2I don't need to mute that p... by Bud Notable Contributor 0 2 | 0 | 2 | |
Open | Communities have some standard "sections". None of these sections though are really appropriate for "guides"."Documen... by abureaux MVP Regular Contributor 0 2 | 0 | 2 | |
Closed | It would be great if we could hover over labels to get the label description:I'm aware we can go to the "See Descript... by Bud Notable Contributor 1 2 | 1 | 2 | |
Closed | Sometimes, users don't realize they have outstanding ideas that Esri staff have flagged as Needs Clarification. I won... by Bud Notable Contributor 1 4 | 1 | 4 | |
Open | In Survey 123 it would be nice to be able to change the GPS icon. Quite often we use a custom map to navigate to a po... by CareyPrendergast1 New Contributor II 1 0 | 1 | 0 | |
Open | To submit a new idea, I currently have to search through 89 different idea exchanges to find the right one. Having s... by lmurrayADOT New Contributor III 4 8 | 4 | 8 | |
Closed | Pretty simple.Collector has been deprecated for 18 months, but it still shows up in the products menu when trying to ... by AlfredBaldenweck MVP Regular Contributor 0 3 | 0 | 3 |
Idea Submission Guidelines
