Allow Editing Code Blocks When Editing Posts
602
02-10-2024 10:51 PM
Status: Closed
MErikReedAugusta
Occasional Contributor III
Let's say I put a code block in a post like so:
def Main():
  print(hello
if __name__ == '__main__':
  Main()
 Oh, whoops, a typo!  I forgot the parenthesis after "hello" on line 2.  Or sometimes I realize I didn't word a comment clearly enough, or I forgot to include some piece of code.
But I can't edit a code block once it's embedded.  I have to select it, delete it, and start again.
Sure, I can do copy/paste with the code in the code block to speed the process slightly, but it's still a pain.  Why not allow users to hit an edit button on that code block and pull that dialog back up to make their changes?
5 Comments
DanPatterson
def Main():
  print(hello) ## oops
  Main()
so this procedure isn't working
KenBuja
Sometimes I can double click on the code block to open up the editing dialog, but more often, as @DanPatterson mentions, I have to click on the code block, then click the "Insert/Edit code sample" button to begin editing it.
JesseCloutier
Hi @MErikReedAugusta, per @DanPatterson and @KenBuja, we've also tested the editing process by double-clicking the code block and doing a single click to select > use the code feature. These both worked on our end, though we note that there seems to be an inconsistent experience referenced when it comes to the double-click method. Because there is a way to do this, I'm going to close this idea but am tagging @SimiBasu for visibility in advance of an update we anticipate for the Esri Community platform later this year that's expected to improve the post editor.
JesseCloutier
Status changed to: Closed
MErikReedAugusta
Ah, I hadn't stumbled upon either of those methods.  I'll start giving them a shot.
Thanks, all!
