We are using an ArcGIS Pro parcel fabric and often rely on the Align Features tool to fix up certain gaps/overlaps/old join mistakes in the data. While this typically works ok, the Align Features tool seems to only honour the GDB topology, even if I have Map Topology specified in the Edit ribbon. With how our connection lines intersect our parcel lot lines, this means the Align Features tool will crack the data at these intersections. The video below demonstrates the behaviour I am describing:
The Move tool has similar behaviour; however, the Move tool honours the topology setting in the Edit Ribbon as well as the visible layers in the map, so we can get around this by setting the topology to Map topology and also disabling visibility of our connection lines. The same process has no impact on the Align Features tool, currently.
I am requesting that the Align Features tool be enhanced to honour the topology that is set in the Edit ribbon.
