How to set the url of the print widget with a template created by the user?
342
08-26-2021 07:38 AM
Jcordovafredes
Hello, I tell you the following:
In ArcMap create a design template following the instructions in this documentation: Publish a print service with custom layouts from ArcMap—ArcGIS Server | Documentation for ArcGIS Ent...
I publish it as a geoprocessing service and it appears in the content of my portal
When I go to the appBuilder and the Print widget, it gives me the following parameters by default:
Service URL: https://gistest.esval.cl/server/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20...
I want to know how I can change the Service URL so that the template that it creates by default appears, since the only urls that appear in arcmap are the following:
SOAP Service URL: https://AINALRAMI.ESVAL.HOLDING:6443/arcgis/services/Map_jose_prueba/GPServer
REST Service URL: https://AINALRAMI.ESVAL.HOLDING:6443/arcgis/rest/services/Map_jose_prueba/GPServer
VamsiKrishnaYARRAMAASU
Hello,
Widget will show all the templates that are published with the Print Service. You can select the published custom template as "Default Template" from the "Default Layout" option in the Widget configuration.
Best,
Vamsi
Jcordovafredes
I know that, what I can not achieve is to be able to print a template to make by default, I understand that I must enter the url, but there I am standing
