eSearch BY SPATIAL not working
648
6
11-16-2022 06:50 PM
RodWoodford
New Contributor II
Hi Robert,
Currently using Esearch 2.23 and cannot get the "available spatial relationships" options to select, which means the by spatial option does not function. Can you please assist.
cheers
Rod
RobertScheitlin__GISP
@RodWoodford Fixed in 2.23.1 release today.
@RodWoodford so you mean that when you try and check one or more of the options nothing happens? What are the errors in your browsers web console?
RodWoodford
New Contributor II
Yep that's correct. You can tick the boxes and click ok , but nothing is saved. If you open it again nothing is ticked.
RodWoodford
New Contributor II
Thank you, Robert,
I will test today and get back to you.
cheers
Rod
TaniaH
@RodWoodford
Hi Rod,
Were you able to get this working?  I have downloaded the new release and am still experiencing this problem?
Thanks, Tania
RodWoodford
New Contributor II
Yep works as it should. Maybe clear your cache if you have setup all the files correctly.
