eSearch 2.23.1 - Query Layer export to CSV
311
01-05-2023 03:55 AM
RodW
Hi Rob,
Currently using eSearch 2.23.1 on 10.9.1 and are experiencing issues trying to export to CSV for multiple selections. What I have discovered is if you use a query layer within eSearch it works fine, however you cant export to CSV multiple results from the query layer or other non query layer service setups. However If I remove the query layer service search from my eSearch setup the export to CSV for other non query layer services multiple selections searching works again. My question is, can you test that query layers are causing this limitation when included with other layers within eSearch. Note single selections work, its just multiple selections wont export to CSV.
Cheers
RodWoodford
New Contributor II
Hi Robert have you had a chance to look at this?
