Edit only one column
125
10-18-2021 02:39 PM
Jcordovafredes
In appbuilder I have the attribute table with information ready to view or filter, which is good, I wanted to know if it is possible to make only one column editable, and if possible, how?
jcarlson
MVP Frequent Contributor
Take a look at the Control edits on a per field basis on the Esri docs. I'm sure there' a way to hard-code such a restriction into a custom web app, but it may be simpler to configure the layer (or a view of the layer) to restrict edits to the field in question through its editing settings.
- Josh Carlson
Kendall County GIS
