Cannot Create ArcHydro AddIn
762
03-02-2023 11:18 AM
RobertStevens
I am using arcgis Pro 3.1
I am experienced with arcgis Pro, but not at all familiar with ArcHydro. I have the .msi download from the archydro resources website, the 3.5.0 version. I have installed this software
My understanding is that this software must be added to arcgis pro. I use pro's Add-In Manager:
Add-In Manager => Options => Add Folder (Load all Add-Ins without restriction is set)
and this brings up a browse window. But this browse window does not list C:\ProgramData which is where the .esriAddInX file for ArcHydro is located. Why not?? Thus I am unable to load the Add-In.
Am I correct in thinking that ArcHydro needs to be loaded as an Add-In?? Regardless of my lack of understanding of ArcHydro I do not at all understand why the browser window does not display under C:
the ProgramData subdirectory (it does, for example display Program Files)
DeanDjokic
You should not have to do anything after running Arc Hydro install .msi (assuming it successfully installed).  The Arc Hydro add-in should just "appear" next time you open Pro and so should the Arc Hydro Pro toolbox.  If it does not, try to uninstall it (using Windows Add/Remove Programs) and then installing it again.  Make sure that all instances of ArcGIS Pro are closed before you do uninstall/install.  You will need admin rights for installing.
DeanDjokic
RobertStevens
Ty for the response.
