How do I see the length of a line while drawing in ArcGIS Pro
1534
10-06-2020 08:08 AM
ScottJohnson2
In ArcMap, while drawing a line the bottom display would show direction and total length.  Is there a way to show this in Pro?  Thanks in advance.
PatrickHuls_SpatialNinja
Hi Scott,
Yes, you can. Toggle on the Dynamic Constraints.
Dynamic constraints—ArcGIS Pro | Documentation
Solutions Engineer | @SpatialNinja | Telecommunications
Hi Scott,
ScottJohnson2
Thanks Patrick.  I have tried using the Dynamic Constraints.  When using this the length resets every time a vertex is put down.  Is there a way to see the total length accumulate after setting multiple vertices?  I feel like I am missing something simple.  Thanks again for your response.
Scott
GrantDickins_ESCO
Hi. When I turn on Dynamic Constraints, even while actively drawing, during or after drawing a graphic line on the map I can not see any length dimensions? Is there meant to be a pop up, a display in the lower status bar? Please advise.
