You don't have time to worry if the programs you use are going to keep pace when your hardware or operating systems change. We wanted to reassure you that Esri is already hard at work testing ArcGIS with Windows 11 to ensure your seamless transition to the new operating system later this year.
With active Esri maintenance or a subscription, you can be confident that any ArcGIS product in the General Availability phase of the Esri Product Lifecycle will continue to be certified with your new operating systems, browsers, and databases. To learn about what's included in your compatibility testing benefit, read our comprehensive testing blog: https://www.esri.com/arcgis-blog/products/arcgis/administration/esri-compatibility-testing-to-reduce...
