Hello everybody, I realize this is very similar in subject line to a post from three years ago but I found that several days ago and still cannot get to fixed.
I recently updated to the most recent version of ArcGIS Pro (3.0.2) and now whenever I try to use arcgisbinding R crashes immediately. The package loads and arc.check_product is able to attach but if I use any functions I get an immediate fatal error. Would love some help.
What versions of R and RStudio are you working with? If possible, please try upgrading to R 4.2 as there are some known issues with earlier releases of R and the bridge in certain cases. If that doesn't help, post back here and we can dig in further.
Cheers, Shaun
Cheers, Shaun
I have updated to R 4.2.2 with RStudio 2022.07.1+554 and still get the issue. I can run arc.check_product()
product: ArcGIS Pro (13.0.0.36056)
license: Advanced
version: 1.0.1.300
but RStudio session aborts when I try arc.open():
ozone.path <- system.file("extdata", "ca_ozone_pts.shp",
package="arcgisbinding")
ozone.arc.dataset <- arc.open(ozone.path)
Any help would be greatly appreciated.
Andy
Are you able to see if the same code works from a plain RGui 4.2.2 session independently of RStudio? Can you check for any crash dumps in %LOCALAPPDATA%\CrashDumps with names like "rsession*.dmp" and if any of those files exist, send one to me via private message? I can look at what the crash itself says. Finally, could you share what licensing mechanism you're using, and whether opening ArcGIS Pro itself is working OK? Thanks!
Yup, that was it! I've been updating RStudio but not R itself 😐 I got it working, thanks Shaun!
