Unable to display map on android
985
01-05-2023 09:57 AM
TasawarAhmad
I am learning to integrate QT with arcgis runtime api.
I have been able to display map on desktop, however after deploying it for android the application crashes.
Can anyone pls guide me on this?
Development System:
QT Creator 9.0.1
based on QT 6.4.0 (MSVC 2019)
Android JDK: 11.0.16
Android NDK: 23.1.7779620
Openssl installed.
Deployment Device:
Snapdragon 845
Android 10
StackTrace:
I mple.DisplayMa: Late-enabling -Xcheck:jni
E mple.DisplayMa: Unknown bits set in runtime_flags: 0x8000
I Perf : Connecting to perf service.
I FeatureParser: can't find beryllium.xml in assets/device_features/,it may be in /system/etc/device_features
E libc : Access denied finding property "ro.vendor.df.effect.conflict"
E Perf : Fail to get file list org.qtproject.example.DisplayMap
E Perf : getFolderSize() : Exception_1 = java.lang.NullPointerException: Attempt to get length of null array
W System : ClassLoader referenced unknown path:
W mple.DisplayMa: Accessing hidden method Landroid/content/ContextWrapper;->getDisplay()Landroid/view/Display; (greylist, linking, allowed)
D ForceDarkHelper: updateByCheckExcludeList: pkg: org.qtproject.example.DisplayMap activity: org.qtproject.qt.android.bindings.QtActivity@4029d6d
I chatty : uid=10314(org.qtproject.example.DisplayMap) identical 1 line
I chatty : uid=10314(org.qtproject.example.DisplayMap) identical 11 lines
D Qt JAVA : Class org.qtproject.qt.android.bluetooth.QtBluetoothBroadcastReceiver does not implement setActivity method
D Qt JAVA : Class org.qtproject.qt.android.multimedia.QtAudioDeviceManager does not implement setActivity method
D Qt JAVA : Class org.qtproject.qt.android.positioning.QtPositioning does not implement setActivity method
W linker : Warning: "/data/app/org.qtproject.example.DisplayMap-iw3jX7ShJnypIGHFe-hEzg==/lib/arm64/libc++_shared.so" unused DT entry: unknown processor-specific (type 0x70000001 arg 0x0) (ignoring)
I QtCore : Start
I Qt : qt started
I Qt JAVA : Can't find '/data/app/org.qtproject.example.DisplayMap-iw3jX7ShJnypIGHFe-hEzg==/lib/arm64/libQt6MultimediaQuick_arm64-v8a.so'
I qt.positioning.android: Positioning start
W linker : Warning: "/data/app/org.qtproject.example.DisplayMap-iw3jX7ShJnypIGHFe-hEzg==/lib/arm64/libEsriCommonQt_arm64-v8a.so" has unsupported flags DT_FLAGS_1=0x81 (ignoring unsupported flags)
E AndroidRuntime: FATAL EXCEPTION: qtMainLoopThread
E AndroidRuntime: Process: org.qtproject.example.DisplayMap, PID: 12572
E AndroidRuntime: java.lang.UnsatisfiedLinkError: dlopen failed: cannot locate symbol "_ZNK10QJniObject15callVoidMethodVEP7_JNIEnvP10_jmethodIDSt9__va_list" referenced by "/data/app/org.qtproject.example.DisplayMap-iw3jX7ShJnypIGHFe-hEzg==/lib/arm64/libEsriCommonQt_arm64-v8a.so"...
E AndroidRuntime: at java.lang.Runtime.load0(Runtime.java:938)
E AndroidRuntime: at java.lang.System.load(System.java:1631)
E AndroidRuntime: at org.qtproject.qt.android.QtNative$3.run(QtNative.java:472)
E AndroidRuntime: at org.qtproject.qt.android.QtThread$2.run(QtThread.java:51)
E AndroidRuntime: at org.qtproject.qt.android.QtThread$1.run(QtThread.java:25)
E AndroidRuntime: at java.lang.Thread.run(Thread.java:919)
I Process : Sending signal. PID: 12572 SIG: 9
22:34:53:
"org.qtproject.example.DisplayMap" died.
JamesBallard1
Hi @TasawarAhmad ,
 We are familiar with this problem.  Unfortunately with Qt 6.4, the ABI was broken so our Map SDK libraries (built with Qt 6.2.4) do not work.
You should be able to get it working if you use Qt 6.2.x, or 6.3.
It is fixed in Qt itself, but not until 6.4.3. More details here https://bugreports.qt.io/browse/QTBUG-109428
JamesBallard1
Hi @TasawarAhmad ,
TasawarAhmad
Thank you. After downgrading to qt 6.2.4 everything seems to work.
