Using timedelta to add days to a start date
263
06-06-2024 07:25 PM
JasmineSpring
New Contributor III
Hello
I am trying to create a scriptool  to select the survey data after a certain start date
If Annual_Growth is 10 I want it to add 20 days to the  Initial_Date to give the start date
If Annual_Growth is 20 I want it to add 50 days to the  Initial_Date to give the start date
Survey_Data = arcpy.GetParameterAsText(0)
Annual_Growth = arcpy.GetParameterAsText(1)
Initial_Date = arcpy.GetParameterAsText(2)  #Date input (date format is dd/mm/yyyy)
T_date = datetime.datetime(Inital_Date)
start_date = T_date + datetime.timedelta(days = num_days)
if Annual_Growth ==10: num_days = 20
elif Annual_Growth == 20: num_days = 50
Where_Clause = "DateTimeUTC >= '{}'".format(start_date)
arcpy.management.SelectLayerByAttribute(Survey_Data, "NEW_SELECTION", Where_Clause)
The first issue I run into is that the initial date input is perhaps in the wrong format for timedelta to add the days ?? Any help would be appreciated. Thank you
JasmineSpring
New Contributor III
Thanks for reply Tom. Yep thats where I started also. Got there in the end. In a roundabout way.
Date_last_treatment = arcpy.GetParameterAsText(1)
AGrowth = arcpy.GetParameterAsText(2)
Initial_date=datetime.datetime.strptime(Date_last_treatment,'%d/%m/%Y')
Growth = int(AGrowth)
if Growth == 10:
    Ndays = 10
elif Growth == 20:
    Ndays = 20
N_date = Intial_date + datetime.timedelta(days = Ndays)
Start_date= datetime.datetime.strftime(N_date, '%d/%m/%Y')
Start_date1 = "timestamp'{}'".format(Start_date)
Where_Clause = "DateTimeUTC >= {}".format(Start_date1)
Tom_Laue
New Contributor III
A couple things come to mind…
  1. When testing, I would add to your script
    1. print(type(Initial_Date))
      1. That way you can tell what date type it is and research how to do a time delta to that format (or if you need to convert it to a different datetime format)
  2. I have seen issues where a date query doesn’t work unless I give it a range of dates.
    1. Date > 6/6/2024
      1.      In some cases that does not work
    2. Date > 6/6/2024 and Date<1/1/2099
      1.      Works when the first one doesn’t
JasmineSpring
New Contributor III
if Growth == 10:
    Ndays = 10
elif Growth == 20:
    Ndays = 20
