Use different license level in stand alone script
886
09-18-2021 11:43 PM
mody_buchbinder
Occasional Contributor III
When we wrote a standalone Python script using ArcMap python (version 2.7) and wanted that it will use a different level license then the default we used "import arcinfo" or "import arcserver" if we need to use server license.
I could not find any way to do it if I use Pro arcpy (version 3). The CheckInExtension, CheckProduct and other function does exists but there is no way to change the default license. Tring to old import option gives an error.
Any idea?
DanPatterson
MVP Esteemed Contributor
from Accessing licenses and extensions in Python—ArcGIS Pro | Documentation
my reading is that licensing is set at the organization level and there is no way to set a different license level
Only ArcGIS Pro uses licensing through the organization. Other ArcGIS Desktop applications—ArcMap, ArcCatalog, ArcGlobe, and ArcScene—use the local ArcGIS Administrator application to set levels and extensions.
... sort of retired...
mody_buchbinder
I was hoping  it is only my poor English  understanding 🙂
Can somebody from esri comment on this - it is important functionality that exists for ArcMap
JoshuaBixby
How are you licensing ArcGIS Pro?  Single-Use, Concurrent-Use, Named User?
mody_buchbinder
What we really like is to use local server license (import arcserver) on a machine that does not have pro installed.
If Pro is installed in most cases taking the default license is fine.
