Script tp read users last login
276
11-29-2023 12:00 PM
kapalczynski
Occasional Contributor III
I have been using this script for quite some time ... It reads out AGOL account and creates a csv file for those users that have not logged in from 80-90 days.
But recently started getting an error on line 10 below   lastLogintime = user.lastLogin/1000
I am assume this is from the recent AGOL Update?
did it change from    user.lastLogin
ERROR
  File "K:\GIS Share\GIS_AGOLProcessing\UsersAboutToExpire.py", line 84, in <module>
    main()
  File "K:\GIS Share\GIS_AGOLProcessing\UsersAboutToExpire.py", line 48, in main
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 8920, in __getattr__
    "'%s' object has no attribute '%s'" % (type(self).__name__, name)
AttributeError: 'User' object has no attribute 'lastLogin'
CODE
def main():
    #log_obj.info("-- Starting to Process AGOL Users...".format())
    with open(output_csv, 'w', encoding='utf-8') as file:
         csvfile = csv.writer(file, delimiter=',', lineterminator='\n')
         csvfile.writerow(["username", "email", "roleID",
                           "level", "disabled", "role",
                           "licenseType", "lastLogin", "daysSince"])
         counter = 0
         for user in user_list:
            lastLoginTimeConvert = (datetime.utcfromtimestamp(lastLogintime).strftime('%Y-%m-%d %H:%M:%S'))
            format = '%Y-%m-%d %H:%M:%S'
            lastLoginDate = datetime.strptime(lastLoginTimeConvert, format)
            lastLoginDATE = datetime.now() - lastLoginDate
            lastLoginDAYS = lastLoginDATE.days
            varDisabvled = user.disabled
            #if lastLoginDAYS > 80:
            if lastLoginDAYS in range(80,90):
                if varDisabvled == False:
                    try:
                        varusername = user.username
                        varemail = user.email
                        varRoleID = rol_ids[user.roleId]
                        varlevel = user.level
                        vardisabledValue = user.disabled
                        varrole = user.role
                        varlicenceType = user.userLicenseTypeId
                        varLastLogin = lastLoginDate
                        varLastLoginDays = lastLoginDAYS
                        z = (varusername if isinstance(varusername, list) else [varusername]) + [varemail] + [varRoleID] + [varlevel] + [vardisabledValue] +  [varrole] + [varlicenceType] + [varLastLogin] + [varLastLoginDays]
                        output.append(z)
                        counter += 1
                        csvfile.writerow([varusername, varemail, varRoleID,
                                    varlevel, vardisabledValue, varrole,
                                    varlicenceType, varLastLogin, varLastLoginDays
                    except KeyError as e:
                        print(user.username, e)
            print(counter)
Tom_Laue
New Contributor III
Make sure your AGOL account you're running the script from is still an AGOL Admin in your org.
If not (like before I was made an Admin in my Org) I could only view my own user details via Python but now I can see others lastLogin.
I just verified this using a test account in AGOL and I get the following error (which I don't get via my Admin login).
Tom_Laue
New Contributor III
kapalczynski
Fantastic that was it.... we had reset this user account and for some reason it was removed from admin level.  Pointed to new account and its working...
THANKS @Tom_Laue
kapalczynski
I simplified it working from this example and same error
https://support.esri.com/en-us/knowledge-base/how-to-determine-the-last-login-in-arcgis-enterprise-p...
import arcgis
import time
from arcgis.gis import GIS
#For ArcGIS Online
gis = GIS('https://xxxx.maps.arcgis.com', username="username", password="password")
print("connected")
a_users = gis.users.search(query='', max_users=20)
a_users
for a_user in a_users:
    if a_user. lastLogin != -1:
        last_accessed = time.localtime(a_user. lastLogin/1000)
        print(str(a_user. fullName) + " was last active on: {}/{}/{}\n".format(last_accessed[0], last_accessed[1], last_accessed[2]))
    else:
      print(str(a_user. fullName) + " has never logged in.\n")
ERROR:
connected
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 8917, in __getattr__
return dict.__getitem__(self, name)
KeyError: 'lastLogin'
During handling of the above exception, another exception occurred:
File "K:\GIS Share\GIS_AGOLProcessing\test.py", line 18, in <module>
