python error for f"{os.path
365
03-24-2023 09:54 AM
anonymous55
Occasional Contributor II
Hello
I am getting error to run this code with Python 2.7
Error invalid characters at this part
f"{os.path.splitext(txtFileNameWithExt)[0]}_{datetime.datetime.now():%Y_%m_%d}"
how can I fix this it? I need to run it on 2.7 .
#rename shapefile
txtFileNameWithExt = "Ops.shp"
txtFileNameNoExt = f"{os.path.splitext(txtFileNameWithExt)[0]}_{datetime.datetime.now():%Y_%m_%d}"
arcpy.env.workspace = my_Path
arcpy.Rename_management(txtFileNameWithExt,f"{txtFileNameNoExt}.shp")
by Anonymous User
Not applicable
yep,  need to format the date there...
#rename shapefile
dte = datetime.datetime.now()
txtFileNameNoExt = "{}_{}".format(os.path.splitext(txtFileNameWithExt)[0], dte.strftime('%Y_%m_%d'))
arcpy.Rename_management(txtFileNameWithExt,"{}.shp".format(txtFileNameNoExt))
by Anonymous User
Not applicable
f decorators are Python 3.  You'll have to use .format() like this:
#rename shapefile
txtFileNameNoExt = "{}_{}".format(os.path.splitext(txtFileNameWithExt)[0], datetime.datetime.now(%Y_%m_%d))
anonymous55
Thanks for replay
I am getting error using your code
File "C:\Sch\osp.py", line 74
txtFileNameNoExt = "{}_{}".format(os.path.splitext(txtFileNameWithExt)[0], datetime.datetime.now(%y_%m_%d))
SyntaxError: invalid syntax
by Anonymous User
Not applicable
#rename shapefile
