Hi @JAYAKUMARKUMAR
The arcpy.SetProgressorPosition() is called after each processed feature class, avoiding freezing or incorrect updates.
Please try like this in your script:
# Set the progressor
arcpy.SetProgressor("step", "Copying shapefiles to geodatabase...",
0, fc_count, 1)
# Create a file gdb to contain new feature classes
arcpy.CreateFileGDB_management(arcpy.env.workspace, "fgdb.gdb")
# For each shapefile, copy to a file geodatabase
for shp in fcs:
# Trim the '.shp' extension
fc = os.path.splitext(shp)[0]
# Update the progressor label for current shapefile
arcpy.SetProgressorLabel("Loading {0}...".format(shp))
# Copy the data
arcpy.CopyFeatures_management(shp, os.path.join("fgdb.gdb", fc))
# Update the progressor position
arcpy.ResetProgressor()
https://pro.arcgis.com/en/pro-app/latest/arcpy/functions/resetprogressor.htm
